01-17-2023
10:56 PM
11:03 PM
SamanthaW
Our PIXMA mx922 prints blurry. I have already cleaned the encoding strip with hot water.
When I print a black and white text document. some lines on a printed document are sharp and crisp, while others are faint and blurry. These crisp and blurry lines alternate all the way down the page.
When I print a mixed color and black text document (such as a screen capture of this current page), the color sections are sharp but the black ink sections are blurry as mentioned previously.
The blurry text almost looks like a double image of the letters.
01-18-2023 04:53 PM
Did you have the problem BEFORE you cleaned the encoding strip with hot water? Or AFTER cleaning it?
Why did you clean it?
01-18-2023 11:10 PM
Yes I have that problem before also. I cleaned around 4 times using settings option for both A and All B but problem did not solve. Then I cleaned the header with hot water but same issue still.
03/02/2023: New Firmware Updates Are Available:
EOS R7 - Version 1.3.0EOS R10 - Version 1.3.02/07/2023: New product announcements!
