01-09-2023
10:49 AM
09:09 AM
Something weird happened to printer. It prints correctly from computer or direct from phone. When I try to direct copy from a scan it will only print in a little spot. It takes whole picture and reduces it to miniature size. I have reinstalled software and drivers but it did not correct issue. Please help.
01-10-2023 08:16 PM
Hi nonjaann! Thanks for posting in the Canon Community Forum. I see that your PIXMA TS3122 is reducing the image to a miniature size when you are trying to copy.
I understand that the printer works normally when you print a document from your computer. Therefore, I recommend that you check the paper size on the printer’s display (the little screen on the printer near the buttons).
The printer’s display is divided into two halves: Upper and Lower. In the lower half of the display, you should see the paper size.
If you are printing on regular copy paper that is 8.5x11 inches, please make sure that you see “LTR” in the bottom half of the display. If you see KG or just the letter L by itself, you need to change it to LTR.
To change the paper size, you’ll need to press the PAPER SELECT button below the printer’s display. The symbol on the Paper Select button looks like a sheet of paper with a folded corner in the lower right. Just press that button repeatedly and stop when you see LTR in the lower half of the printer’s display. Then, press the OK button.
If you need to see an illustration of the display and paper select button, please visit the following section of the manual (link below) and skip to step 5:
https://ij.manual.canon/ij/webmanual/Manual/All/TS3100%20series/EN/UG/ug_l_01_04_c.html
If the printer is still reducing the size of the scanned image, please write back with answers to the following questions:
You may also want to visit the following sections of the manual for more information.
https://ij.manual.canon/ij/webmanual/Manual/All/TS3100%20series/EN/UG/ug_l_03_02_c.html
https://ij.manual.canon/ij/webmanual/Manual/All/TS3100%20series/EN/UG/ug_c_02.html
I hope this information helps. Thank you for choosing Canon.
01-09-2023 11:00 AM
Hello!
So that the Community can help you better, we will need to know more information.
Do you see any error messages?
Which Computer Operating System are you using (Windows 7/8/10/11 or macOS 10/11/12)?
How do you connect to your printer (USB or WiFi)?
Any other details you'd like to give will only help the Community better understand your issue.
If you're in the United States, and this is an urgent support need, please click HERE to visit your My Canon Account to discover your personalized support options.
If you're outside the USA, please click HERE to find support options in your country.
Thanks and have a great day!
01-09-2023 04:59 PM
Computer is Windows 8. I use both connections. Wifi direct for phone. USB for computer. It is an all in one printer. Previously I was able to direct copy a paper without connect to either. It worked fine. Then it went wrong on the straight copy.
01-10-2023 08:16 PM
01-18-2023 06:31 PM
I apologize for taking so long to respond. I had to be out of town for several days. I followed the suggestion on checking the paper size on printer. There was a single letter L. Upon recommendation, I continued to cycle through size options and find the designated LTR. This change fixed the copy issue.
Do you know what that single L stands for? Just curious. Thank you for the guidance on fixing the printer issue.
