04-24-2023
01:50 AM
09:48 AM
We are a two-Canon-printer household. My wife has a Pixma MX472 printer and I have a Pixma G7020. I have used my G7020 to scan documents multiple times (using IJ Scan Utility) without problems. However, a couple of days ago I put a document in my printer and tried to scan it and I got a blank page. It took me some time to realize that the app was scanning from my wife's MX472.
Now, ordinarily this wouldn't be a big issue because as long as I can scan the source doesn't matter. However, in this case I have a 400-page document that I want to scan with my Automatic Document Feeder, which the MX472 doesn't have -- and I don't want to have to do it a page at a time!
In looking into this, I discovered I have an IJ Network Scanner Selector EX and one called IJ Network Scanner Selector EX2. I hadn't paid any attention to these in the past because everything just worked. However, now I noticed that the EX app is set to scan from the MX 470 Series, and the EX2 app is set to scan from the MX 7000 Series. Each one has only one choice, and I don't see any way to change them.
I tried disabling EX; when I run the IJ Scan Utility, it still wants to scan from the MX472. I tried exiting from EX; it still wants to scan from the MX472.
What do I have to do to get the software to scan from the G7020?
04-24-2023 06:10 PM
Well, I'm embarrassed. When I didn't see an answer here, it occurred to me that if I uninstalled the EX app, the EX2 app would have to be used and the correct printer would be used. After I did that, though, when I went to run the IJ Scan Utility, I noticed that at the top of the screen there's a "Product Name" dropdown, which I'd completely missed before. I used that to select my printer and everything worked perfectly.
04-24-2023 06:10 PM
