PIXMA G3270 connected, frozen
mark-flint
I received a replacement on warranty, went through the setup and connection process. It has a "processing, please wait momentarily" message on the screen, will not print.
3 REPLIES 3
Moderator
Moderator
Thanks for joining the conversation, mark-flint!
This community is designed for your fellow Canon owners to help each other out with any problems they may encounter. If this is a time-sensitive matter, click HERE search our knowledge base or register your Canon gear HERE to access additional support options.
Thanks and have a great day!
Greetings ,
Did you remove the old printer from your system and restart before trying to install and connect the new printer?  Even if it's the same model,  the connections are not interchangeable.
Thanks. I did uninstall the old printer. I am hoping the problem, now self-resolved, was a one-off. It had done an update, which may have led to the issue.
