PIXMA G3270 won't stay online, loses Wi-Fi connection
mangurian
Rising Star
If I leave it on, after a while it will lose wifi connection.  I have to go to the printer room and cycle printer power to get back online.  I have very solid wifi, so it is the printer losing the connection.  Is there a setting for this ?
Thanks,
1 REPLY 1
Greetings ,
If your Wi-Fi signal is strong and stable, this likely has to do with DHCP settings.  Login to your router's admin portal and look at your list of attached devices.  Assign the printer a static IP address.
Once done, I suggest you uninstall and reinstall the printer as a TCP/IP printer on any systems you plan to use it with.
