PIXMA G3260 Computer can't find printer
ronnieb
I have a Pixma 3260 which I didn't use for 2 months. When I returned to it I printed a few pages but none of them were good. The black faded and now nothing prints. When I tried to use the maintenance program it couldn't find the printer. I tried reinstalling the printer using the Canon app but it fails when installing the drivers. I don't under stand why this happened because in the previous installation step the printer was found. I saw in the device manager the printer is listed however it has a default Windows name so i thought it had to change. I searched the forum for the printer not found and found a post that mentioned driver signature enforcement that provided a link to disable the signature enforcement, https://www.isunshare.com/windows-11/how-to-disable-driver-signature-enforcement-on-windows-11.html . There are 4 different way to do this and I've tried every one but none of them work. What can I do?
ronnieb
I eventually discovered there is a maintenance mode on the printer itself and flushed the ink. It's back to normal now. I'm disappointed I can't install the maintenance program because there are some features on it that I like.
You can consider this solved.
5 REPLIES 5
DerrickL
Whiz
Whiz
Is your printer a Pixma G3260, a super tank printer? I think the best way to get this printer printing again is to start from the beginning, so let me ask this important question, what Windows version are you using? Once we know that I think you need to remove the printer and then reinstall it using the very latest drivers for your printer.
I'm using Win11. I've deleted and re-installed it. I eventually discovered there is a maintenance mode on the printer itself and flushed the ink. It's back to normal now. I'm disappointed I can't install the maintenance program because there are some features on it that I like.
ronnieb
DerrickL
Whiz
Whiz
You  can't install this maintenance program for Windows 11?
https://pdisp01.c-wss.com/gdl/WWUFORedirectTarget.do?id=MDIwMDAwNTM4NzE4&cmp=ABR&lang=EN
I installed it but it can't find the printer.
