04-19-2025
03:17 PM
09:24 AM
I ran a nozzle check and the right side printed black and all the other colors but the left side column was all blue.
04-21-2025 02:10 PM
Hi royalmorning,
Please print another nozzle check. To do this, please follow these steps:
1. Please press the wrench and screwdriver button on your PIXMA G3260 one time.
2. Press the right arrow 3 times to select Maintenance and press OK.
3. Press OK on Nozzle Check.
A test page will print. Please compare your printout with the example on this page:
G3260 > Maintenance > Examining the Nozzle Check Pattern
If your nozzle check did not print correctly, please follow all of the steps provided on this page:
G3260 > Maintenance > If Printing Is Faint or Uneven > Maintenance Procedure
If you continue to have difficulties, please contact one of Canon's Technical Support Representatives via phone or chat. To contact a Technical Support Representative, please use the link below to log into your My Canon account:
https://mycanon.usa.canon.com
Once logged in, click on your PIXMA G3260 and then click on the Product Support button. When that page loads, click on either the Phone Support button or the Chat Support button to access support.
04-23-2025 09:02 AM
The right column is fine but the left side is printing blue. If I try to print something it comes out with a blue tint to it.
04-23-2025 02:00 PM
Hi royalmorning,
The first yellow bar is not printing at all. You can view what the page is supposed to look like here.
Did you perform an ink flush? If not, please do so.
