11-18-2022 01:24 AM
Hello fellow cannon community I just purchased a new TR4720 from the University Bookstore last week and it worked perfectly on every device in the house. Thank you. However, a OS update for Ventura installed automatically and the scanner printer no longer function. I get a error. When will a new driver be available for this system? Should I return it as the new operating system does not work with the new printer. Failed to open a connection to the device (-21345) I have uninstalled and reinstalled the software for the printer same results. This is for Ventura 13.0.1 printer was purchased last week.
11-22-2022 03:33 PM
Remove the printer and restart your Mac. Once that is done go back into printers and scanner and select add printer.
How many TR4700's appear? When you reinstalled in the printer after the OS update, did you reinstall the Master Setup (Mac) file from the Canon website?
12-03-2022 10:59 AM
No this did not resolve it, thanks for your reply, it says online however it will not wake it up to scan inside of the mac software, the ij scan works however I have to manually turn the scanner on now also. This has the same result as before.
