02-23-2024 05:15 PM
Our MX922 started printing "normal", standard printouts poorly, fuzzy, or characters doubled. The funny thing is if the printer is set to "high resolution paper" (even if paper is just normal paper) and "high quality", the printer prints *very* slowly, but very clearly. The printer is obviously physically capable of creating crisp output but it will only do so in the situation above. This isn't acceptable because the "high quality" printing is very slow, and it does not allow 2-sided printing. Is this something that can be fixed with a driver or firmware update, or is this a hardware problem? Suggestions welcome, thank you!
03-12-2024 12:47 PM
To begin troubleshooting, I would clean the encoder strip in the printer by using the steps HERE.
03-18-2024 03:06 PM
Thank you for the suggestion, I had cleaned the encoder strip a couple of times, and all other cleaning/maintenance suggestions. In the end I just gave up and bought a TR8620a, which is performing quite well so far.
