01-09-2020 05:03 PM - edited 01-09-2020 05:07 PM
Hello. My printer is printing too large. I tried making the printer size smaller on the printer as well, I tried changing the setting in my print setting on my computer.
I have changed the blinking ink cartridges in hopes of repair. Nothing! Any suggestions would be grately appreciated.
Thanks Leslie
01-10-2020 09:34 AM
Hi, Lesliescanon13!
So that the Community can help you better, we need to know exactly which operating system is running on your computer (i.e. Windows or Mac OS, and which version thereof) and which apps you're trying to print from. That, and any other details you'd like to give will help the Community better understand your issue!
Thanks and have a great day!
01-10-2020 10:02 AM
Greetings Leslie,
Not sure what you mean by "printer is printing too large"
Is this text, images, etc???
First thought, check the scale settings. This might be expressed as a percentage %.
Your display settings can also effect this. Please answer Danny's questions as best you can. We can try to help more from there.
01-10-2020 06:09 PM
01-10-2020 06:46 PM
Hi there. {I've had this printer for more than three years. This is the first time this has happened. As I state, I checked the things I felt was necessary. Even made the percentage smaller to 75% on the printer and in the print settings on my computer).
I'm using Windows 10 OS. I'm trying to print a couple of return labels via my email. Didn'r change size to fit an actual label size. Just a standard 11.5 sheet and I cut the paper to fit the size of a label.
I've been doing this for three years nothing different, However, I've never used this merchant before in Amazon. Could it possibly have somethng to do with the way the email was sent to me? Is is not being sent directly back to Amazon but the merchant. As is the other package.
Thank you.
Leslie
01-13-2020 03:01 PM
Hi Lesliescanon13,
What web browser are you using to view your email?
Once the email is open, are you clicking the print icon on that web page or are you choosing the web browser print option?
01-13-2020 04:35 PM
01-14-2020 04:01 PM
Hello.
The ink levels do not affect font sizes. Font sizes are usually controlled by the software that you are using.
Check to see if a "Print" option is inside or around the web page or article that you are trying to print. This should properly format it for printing. If the issue persists, you may have to copy the text and then paste it into a word processing program like Microsoft Word so that you can adjust the font size before printing.
01-14-2020 04:29 PM
Thank you Michael, I'll try it.
Leslie
04-17-2020 02:29 PM
Hi, I'm having similar issue with printing PDFs from Preview. Ever since upgrading my iMac to MacOS 10.14 I've had issues. I do have an unsupported printer now, a Pixma MX860 and there hasn't been any software upgrades on the Canon site in a long time. At first printing a PDF from a website runing Safari the printing issue occured. The work around was to download the file and then open in Preview and it would print fine. Now on MacOS 10.14.6, even opening the file in Preview does not work. The printing is very large and even scaling down the size doesn't work. I've attached an example, this is a PDF I converted to s JPG so that I can insert here. I'll probably just have to get a newer printer as this old trooper only uses 32bit software and if I want to upgrade to the latest MacOS, I need 64bit software.
