02-09-2022 07:43 PM
IJ Scan Utility 2 reports "Cannot communicate with scanner". That utility does select the scanner, so it knows it's there. I just reinstalled the scan utility.
02-10-2022 02:23 PM
OK, I reinstalled the driver AGAIN, and the problem is resolved. I'd have to say, there are different downloads you can do for the multifunction device... somehow my driver was old, and previous reinstalls didn't work or ??? I'd really prefer there to be only ONE download for everything. You have the latest, or you don't. That's for the Canon suggestion box.
02-09-2022 07:47 PM
Mac OS v12.1
02-09-2022 08:04 PM
IJ Scan Utility 2 reports "A scanner driver supporting this software is not installed. Install it and try again. Code:15,230,0". But I've done that 3 times already.
02-10-2022 08:47 AM - edited 02-10-2022 08:47 AM
Hi, antics!
Thanks for posting on our forum! This community is designed for your fellow Canon owners to help each other out with any problems they may encounter. If this is a time-sensitive matter, click HERE search our knowledge base or register your Canon gear HERE to access additional support options.
Thanks and have a great day!
02-10-2022 01:57 PM
OK. I didn't find anything in the KB. Also, most support articles talk about reinstalling drivers (did that) and restarting the internet modem (not the problem because printing works fine over wifi).
02-10-2022 02:23 PM
