02-09-2022 03:35 PM
I just upgraded my MAC to OS Monterey 12.2 and my Canon MG6320 icon is crossed out. How do I upgrade my Canon to be compatible?
02-10-2022 09:52 AM - edited 02-10-2022 09:56 AM
The MG6320 is 7 yrs old. It has not been officially supported under MAC OS since v10.14 Mojave.
Its possible this release will work with some (but not all) subsequent versions of MAC OS. You may be able to use the printer with some or limited functionality under a later OS, without a "Canon" specific driver.
Other possibilities:
Check out "VueScan" (just google it)
Install as plain IP printer:
You can also try using it as a IP printer under Monterey v12.2. The IJ Networking Utility is available under the software tab and will allow you to set the printers IP manually. Given the amount of time that has elapsed, I doubt Canon will release a driver for Monterey. They also offer an upgrade program which offers a path to a new device at a reduced price.
02-10-2022 02:40 PM
Thanks so much, Rick. Your info is so valuable. I did download VueScan and can use it with the Canon in a more roundabout way! Much appreciated! Connie
