05-31-2022 09:11 PM
06-05-2022 10:30 AM
Hi! Yes, a firmware update is available to resolve this issue entirely. You can download the firmware update and find easy installation instructions at canon.us/power.
06-02-2022 11:27 PM - edited 06-02-2022 11:33 PM
I am one of those with the Pixma iP110 mobile printer that is also affected by this issue, and that model has no menu on it as described in all of the "fixes" I keep seeing for the desktop models. I did unplug the router and connect the printer to my MacBook Pro laptop with a USB cable and was able to print. Then, as soon as I reconnect the router, it turns off again. No idea how to figure out how to keep it from connecting to my internet? Any advice? This has reached ridiculous now, thanks Canon!
06-03-2022 02:25 AM
Isn't there a simpler way to get this printer working? I'm not that Tech-savy. Thanks.
06-03-2022 08:43 AM - edited 06-03-2022 08:44 AM
I am using Pixma iP110 mobile printer. The printer will boot up for a while and then it shuts down by itself. May I know if there is any step by step solution to solve this issue as i am not tech savy? I am using WiFi connection from my Apple MBP to the printer. MacOS 12.4. Thanks in advance.
06-03-2022 10:37 AM
My MX492 is working from unplugging router and printer, etc. But I just noticed there is a message on the printer about a firmware update. Does anyone know if this is a fix rolled out by Canon?
06-03-2022 12:15 PM
You mean just unplugging them, then plugging them back in?
06-04-2022 04:19 AM
Basically, Yes. Same thing worked for me, I didn't go into all of the changing of the DNS thingamajigs
Canon Maxify MB2320
Printer started power cycling when Canon screwed everyone else this past weekend. I took the DNS "Fix" and instead of doing all of the steps I only....
Printer bought in 02.2015 and have never installed a firmware update and whatever Canon did this weekend, it still affected mine
06-04-2022 09:33 AM
I have no clue what you are talking about. Can you help in terms that apply to the MX490? I'm not familiar with DNS or IP terminology, but, can follow directions. Thanks!
06-05-2022 10:17 AM
Does anyone know if the firmware update here fixes the problem? - https://www.usa.canon.com/internet/portal/us/home/support/details/printers/inkjet-multifunction/mx-s...
Thanks
06-05-2022 10:30 AM
06-05-2022 04:25 PM
Thanks for the update. Yes, this answers my question, but where is the Accept as Solution button? I don't see it on the page anywhere.
