03-06-2019 07:54 AM
I can not get printer past it making annoying beep (1 beep) and then hearing/seeing scanner arm move a few inches and then it repeats. There is no error message. Just says Canon on screen. No obvious paper jams and ink is seated fine.
Anyone please help!!!!!
03-07-2019 03:34 PM
Hi tech,
Are you trying to scan to a computer and make a copy directly from the printer? Are you able to make a copy directly from the printer?
04-04-2023 03:11 PM
Same problem here. I was able to reset it once, but now I'm unsuccessful.
04-07-2023 10:52 AM
Hi Deenice,
Please connect your PIXMA MX452 directly to a wall outlet, without a surge protector / power strip. If your PIXMA MX452 still does not display the Home screen, please try a different wall outlet. If your PIXMA MX452 still does not power on to the Home screen, your PIXMA MX452 would require service.
If your PIXMA MX452 was purchased less than a year ago, please contact one of Canon's Technical Support Representatives via phone or chat to obtain your in warranty options. To contact a Technical Support Representative, please use the link below:
https://mycanon.usa.canon.com
If your PIXMA MX452 is out of warranty, you are eligible for Canon's Upgrade Program. This is for out of warranty units which have been diagnosed to require service, or for some reason are incompatible with a new or upgraded system. This option allows you a one-time opportunity to purchase a replacement product, discounted from the list price.
If you would like to take part in this option, please call our Sales Department at (866) 443-8002 Monday through Saturday, 9am to 9pm. Let them know you have been working with technical support and the Canon Upgrade Program was offered.
