07-16-2017 10:35 PM
I would like to disable Wifi on this printer. Does anyone know how to do this. I have been through settings but can't seem to find anywhere to do this. Thanks
11-17-2017 01:59 AM
Hi KBH,
The PIXMA MX330 does not have a wireless connection option; it can only be connected via USB cable or Bluetooth. To disable the ability of the machine to be found by a bluetooth-compatible device, please follow these steps:
1. Press the MENU button.
2. Use the arrow buttons to select SETTINGS, then press the OK button.
3. Use the arrow buttons to select DEVICE SETTINGS, then press the OK button.
4. Use the arrow buttons to select BLUETOOTH SETTINGS, then press the OK button.
5. Use the arrow buttons to select ACCESS REFUSAL then press the OK button.
6. Use the arrow buttons to select ON, then press the OK button.
Hope this helps! Should you need further assistance, we ask that you please contact a Canon technical support representative here. A representative will be happy to assist you free of charge.
