06-25-2016 01:23 PM
Called Canon Support and they say it's unrepairable but past 1 year so unreplaceable too. Tried everything including dismantling the printhead assembly to manually clean. Barely used the printer, 1 or 2 prints a month.
Anyone have recommendation on non-Canon I can buy to replace for around the same price range?
08-27-2021 03:37 PM
fixed this by turning on with lid open then closing as soon as cart moved. loaded fine, printed, and then it bricked. oh well.
08-27-2021 08:36 PM
10-14-2021 02:54 PM
worked for me (thus far!)
03-11-2022 11:30 AM
Its sad that canon dont care about their customers... they make error codes that mean nothing, and dont have any fix... they have error codes when we are meant to replace ink when there is still half the ink in its case.
In regards to this error code, I did what others did by turned off and opened the lid as if I was to replace the inks then turn it on.. when starting up its starts a cleaning cycle and hey presto it works. What you need to do is side track it lol if this doesn work just turn it off by the plug socket and repeat opening the ink bay... and turn it on. if this dont work, instead of turning off at mains unplug it from back when its on open the ink bay and plug it back in. Good luck!!!
08-10-2022 06:56 PM
how do you install firmware or driver updates when you can't get past the error? I replaced all the ink cartridges but that made no difference. I don't think the printer is communicating with the ink carriage, it doesn't move to the center when I lift the lid to access the ink carriage.
08-14-2022 04:43 AM
Struggling with B203 as well. I have a MG7540. It has not worked much in it's entire life...yet its faulty. Cost me a fortune in replacement cartridges even without printing. Safe to say there will never be another CANON product in my workflow - this item is designed to fail - much like the Phoebus Cartel engineered products to be replaced after a set time ...eg less value to customers. Can anyone suggest a 3rd party printer that offers reasonable long term ownership value ?
