12-04-2019 08:49 PM
I've installed the most up to date drivers, and Canon software.
But whether I try to access the scanner via Image Capture on Mac or the Cannon IJ software I get the following errors.
Please HELP as I feel like I've made the wrong choice in buying a Canon product now...
12-05-2019 09:17 AM
Hi, myasumura!
So that the Community can help you better, we need to know exactly which version of macOS your computer is running. That, and any other details you'd like to give will help the Community better understand your issue!
Thanks and have a great day!
12-05-2019 09:57 AM - edited 12-05-2019 09:58 AM
In addition, knowing how the device is connected... (USB or Wireless) might also be helpful.
12-05-2019 02:00 PM - edited 12-05-2019 02:08 PM
Currently on MacOS Catalina, Version 10.15.1
Connected Wirelessly atm and prints fine.
Contemplaing whether I should get a cable or not, but the whole reason I got this model was that it should be able to conenct wirelessly.
12-06-2019 07:06 AM
Was this device installed and functioning under Mojave OS (then upgraded), or was it installed under Catalina straight away?
For simplicity and to take control, I recommend installing printers as a TCP/IP device. Using a static IP removess much of the problems associated with a "moving target" on your network.
Once done, open a web browser and enter the IP address of your printer. Does the Scan option work there?
All printer functions (including scanning) should be available, over a cable or cableless connection.
12-06-2019 10:29 AM
It was installed under Catalina right away.
Will try to dedicated IP address, thanks
