11-01-2013 07:13 PM
I have had the MG5320 printer for just over a year now. Everything has been working brilliantly until recently. I am now getting an error: "U052: The type of printer head is incorrect. Install the correct print head"
I have not changed print heads. The only thing I've done is replace empty ink cartriges over the past year and a half, only when needed of course and I haven't done that for quite a while. 3 days ago everything was fine, I had printed a few things perfectly. Now, after no changes or ink cartrige refills, I'm getting this error message.
Please help!!!
I'm on a MacBook Pro from 2009, running Snow Leopard. However, I don't believe it's a computer issue at all...just FYI
11-08-2013 12:12 PM
Hi JimCarey,
I agree, doesn't seem like a computer issue. Since you have not changed the printhead, this error is indicating a damaged or malfunctioning part.
First, try to clear the error by resetting the printer. Disconnect the power from your printer and then press the ON button 5 times. Wait 10 minutes and then reconnect the power. If the error appears again after powering on the printer, then I recommend contacting us to discuss your service options.
