Initial setup of new PIXMA G7020
Ohgeorge
Interrupted at load paper cassette step of initial launch ( first tie plug in of power cord).  How do I startvover or return to this step?  On line manual does not help.  Will use it with my new iMac that no longer has built in cd drive.  As you are aware the printer is supplied with a disc.  Suspect it will only provide software info and related stuff.
1 REPLY 1
ArthurJ
If you did not complete the setup, please unplug the power cord to the printer and then plug it back in. If the printer goes back to the home screen, it should take you to the register paper screen when you load paper into the printer.
For Mac computers, this printer uses the Apple Airprint drivers and you wont need to download a printer or scanner driver. To install the scanner software and additional software, you can click the link below to download the file. After the file is downloaded, go to your recent downloads and run the file.
mac-g7000-1_1-mcd.dmg
If the printer is connected to your network or you are using a usb cord, you will just need to open system preferences and then select printers and scanners. From there you will be able to add the printer to your Mac.
Did this answer your question? Please click the Accept as Solution button so that others may find the answer as well.
