I have a PIXMA TS7722. How do I put it in standby mode so I don’t have to go turn it on every time I
dmarcwilliams
1 REPLY 1
DerrickL
Entering Standby Mode on PIXMA TS7722
Using the Touch Screen
  • Press the Energy Saver button on the touch screen.
  • The touch screen display will turn off, indicating the printer is in standby mode.
Using the Control Panel
  • If your model has an upright control panel, press the Energy Saver button located there.
  • The button will light up when the printer is in standby mode.
Automatic Sleep Mode
  • The printer can automatically enter standby mode after a period of inactivity.
  • You can adjust the time settings for this feature through the printer's settings menu.
Exiting Standby Mode
  • To wake the printer, simply touch the screen or press the Energy Saver button again.
  • The printer will also exit standby mode when a print job is sent or when the paper feeder is opened.
Additional Settings
  • You can manage the auto power settings using the Canon IJ Printer Assistant Tool on your computer.
  • This tool allows you to set the time for automatic power off and on features.
