06-03-2013 03:41 PM
I have a Canon Pixma MX 880 and when I try to change or delete photos on my SD card, I get the following error:
"You need permission to perform this action" and below that:
"You require permission from the computer's administrator to make changes to this file".
Printer is set up wireless.
I am signed on as administrator, can't get access with any user account.
The old problem ridden HP Photosmart I replaced, I could change, delete, etc. without issues.
06-05-2013 04:42 PM
hi ehnco,
It sounds like the Read/Write attribute on the printer needs to be changed. Use the following steps to change the read/write attribute:
button to select
[ Device settings], then press the <OK> button.
button to select [Device user settings], then press the <OK> button.
button to select [Read / write attribute], then press the <OK> button.
button to select [Writable from LAN PC], then press the <OK> button.06-05-2013 04:42 PM
hi ehnco,
button to select
button to select [Writable from LAN PC], then press the <OK> button.06-05-2013 04:44 PM
Thanks ! That solutioned worked. I appreciate your help.
