08-28-2020 07:18 PM
I have a Canon PIXMA MG5320 printer.
I cannot scan documents to my laptop. I have a new HP Notebook 14-dq1043cl with Windows10 (April 2020)
10-07-2020 03:12 PM
Hi Zoeygirl,
Please click on the Windows Start button and in the menu that appears, do you see the Canon Utilities folder?
In that folder, please click on the IJ Scan Utility.
Once the IJ Scan Utility appears, please click the Documents button to perform a scan.
Are you able to scan?
If not, what is the error code that appears at the bottom of the error box that appears?
If the IJ Scan Utility is not found in the Canon Utilities folder, that means it is not installed and that would cause this error as well. To install the IJ Scan Utility, please install the drivers.
To download the drivers, please CLICK THIS LINK
When you click that link, the drivers will download. Once the download is complete, please open/run "mp68-win-mg5300-1_01-ejs.exe" to install.
Follow the on screen prompts to install the drivers.
Once the drivers are installed, please go back to the Windows Start button, Canon Utilities folder and then click on the IJ Scan Utility to perform a scan.
10-07-2020 03:12 PM
Hi Zoeygirl,
