08-26-2014 01:54 PM
Is there a way to turn off the printer's Wi-Fi?
I am running a Canon MG6220 Printer on Windows 7.
I am using the USB cable and not longer need wireless LAN.
Thank you.
10-17-2014 11:39 AM
Thanks Patric.
On my printer the "right FUNCTION button" in step 2 is "Setup > Device settings"
This worked:
Setup > Device settings > LAN settings > Change wireless/wired > Disable LAN
09-24-2014 09:56 AM
Hi wolfv,
To turn the WiFi feature of your PIXMA MG6220 off, please follow these steps:
1. On your PIXMA MG6220, press the HOME button.
2. Use the up or down button to select Setup and press the right FUNCTION button.
3. Use the left or right button to select LAN Settings and press OK.
4. Use the left or right button to select Change wireless/wired and press OK.
From this screen you can deactivate wireless/wired LAN.
10-17-2014 11:39 AM
Thanks Patric.
This worked:
