How do I get my MX420 to print out a fax that is in its memory?
notatechie
2 REPLIES 2
Julius
Rising Star
Hello notatechie,
Please try the following procedure to print the documents in memory:
1. Make sure that the machine is turned on.
2. Load paper.
3. Press the FAX button.
The Fax standby screen is displayed.
4. Press the left Function button.
The Fax menu screen is displayed.
5. Select  Memory reference, then press the OK button.
6. Use the   button to select Print all received documents, then press the OK button.
The confirmation screen is displayed.
7. Use the   button to select Yes, then press the OK button.
All the documents in machine's memory will be printed.
Each time a document is printed, the screen to confirm whether to delete the printed document in machine's memory is displayed.
If you select Yes using the   button and press the OK button, the printed document in machine's memory is deleted.
We hope this helps!
How do I retreive it from my MX492? The direction you give here are not working for me.
