10-24-2024
11:06 AM
11:07 AM
Our Canon ImageClass MF644Cdw won't copy. We can print, but the copy function produces errors every time. We're prompted to shut it off, and error E-302-0001 displays. The shut down never fixes the problem.
In the copy status, the error is described as #853. In reviewing the possible causes for #853, none make any sense in copy mode. They all seem to deal with memory, document size or security settings as transmitted from a pc. The copy function should all happening at the Canon interface so those issues would not apply.
Can anyone help?
10-24-2024 02:38 PM
I have more info to add. It's not just the copy function that won't work. Fax also won't work and brings us to the same error E-302-0001 and the direction to shut down so the issue seems to be in the scanning of the document. #853 shows up in the report for this failed fax attempt as well.
