imageCLASS LBP674Cdw How to go back and set up remote UI
pmoua
hi, we just recently got a color printer model LBP674Cdw. when setting it up the first time I have select no for the Remote UI. now i can't go into the settings without a system management ID and PIN. how do i go back and set that up ? I've tried typing in the IP address on the printer to my search bar but it is saying that i need to enable Remote UI.
1 REPLY 1
Hector
Hello,
The default system pin is 7654321. If the default pin does not work, you can contact our support team at 1-800-652-2666. Our agents would be happy to walk you through the resetting process, You can use the steps in the link HERE to log in and use the UI.
If you continue to run into the issue, you can contact support  Our agents would be happy to assist.
