10-06-2023 04:15 PM
I have a relatively new G7020 and as I did some print head cleaning and deep cleaning I would get fewer colors printing the nozzle check. When I opened the cover I noticed an air pocket in the ink line. How do I get rid of air pockets? I don't see anything in the maintenance manual.
It would be really nice if Canon allowed us to specify which ink color has the air pocket to avoid wasting ink from other reservoirs.
10-06-2023 04:19 PM
I will add that I keep getting error code 5200 which I believe is empty tank. All ink tanks are at 75% or above as the printer is practically new. I would like to understand how the air is getting into the line so close to the print heads. Should I put some vaseline on the connections to the print head cartridge to ensure an airtight seal to avoid back syphoning of air into the lines?
10-09-2023 03:21 PM
Based on the description and error code, it sounds like a hardware failure and the printer would need service.
If the printer is in it's 1 year warranty, I recommend reaching out to Canon support for your warranty options. You will need to register your Canon gear HERE to access additional support options.
If the printer is out of warranty, you would qualify for the Canon Upgrade program. This is for out of warranty units which have been diagnosed to require service or are incompatible with a new or upgraded system. This program allows you the opportunity to purchase a replacement product discounted from the list price. Free ground shipping is included with your purchase.
If you would like to take advantage of this offer, please call our Sales Department at (866) 443-8002 Mon-Sat, 9 AM to 9pm EST excluding holidays.
