05-20-2021 09:41 AM
When I scan 8-1/2"x11" documents using the ADF, the pdf created is 8.5 x 11.147 inches and there's a horizontal line at 11", which is at the end of the paper document. The line is not acceptable to me. Is there a setting I need to apply so the line does not appear and my resulting pdf's are 8.5 x 11 inches? I'm scanning from the panel on the printer and I have it set for letter size.
My Canon is a G7020 model.
Thanks.
05-20-2021 10:56 AM
The ADF will scan up to 8.5 x 14.0 (Legal)
It should not add a line at the bottom of a scanned 8.5x11 page letter.
You may have set a custom paper size unintentianally. I suggest you review settings in the driver or application you are scanning from. If you are scanning from the control panel, check the driver on your system.
05-20-2021 03:37 PM
Paper size was set to "Letter". The paper document is letter size. Device manager said Drivers are up to date. I have all my Windows 7 updates. I looked at Canon's website for Driver updates, but all I could find were instructions for downloading the installation files.
I am scanning from the control panel. Here is a jpg of the pdf (I added a 5-pixel wide blue line to each of the 4 sides when I converted the pdf to a jpg):
05-20-2021 08:44 PM
I downloaded the installation again, but could not get past the "connect page" (The page that shows the 3 images of plugging in a USB cable to the PC, the printer, and turning the printer on). At that point, the Troubleshooter was the only option but it did not help.
I just tried scanning again. This time, when I scan in color or B&W, the pdf is 8.5 x 11 inches. There is still a grey line near the bottom. The grey line is straight but it has a slight slant to it. One end of the line is at the bottom of the pdf. I attribute the grey line to perhaps the ADF rollers dis not grab the paper evenly.
I'm willing to bet when I downloaded the Canon software this time, even though the installation stopped before it finished, new drivers were installed.
05-23-2021 10:54 AM
I don't know if I should start a new discussion or not, but my new question seems to be related to my problem of the horizontal line (My new question is at the end).
I do all my scanning directly from the control panel on my Canon G7020. I noticed when I use the defaults for scanning, the horizontal line appears and the pdf is 8.5" x 11.147". "Original type" says "*Auto scan" (Auto scan is the default). When I go through the menu and change "Original type" to "Document", the line does not appear and the pdf is 8.5" x 11". The documents I'm scanning are on typed paper, 8.5" x 11".
Might I still have a driver problem?
When I change a setting on the control panel, how do I save the new settings so "Original type" does not revert back to "Auto scan"?
06-04-2021 04:11 PM
Hi David121,
Please contact one of Canon's Technical Support Representatives via phone or chat. To contact a Technical Support Representative, please use the link below:
https://mycanon.usa.canon.com
