12-12-2018 11:02 PM
Just got this MX922 a few months ago. In printing barcodes (color or b/w), there are large gaps (always). These gaps appear in other images now and then, but this barcode (shipping label) seems consistent. The placement of the gap varies a bit. Sometimes one from the left AND one from the right (smaller). Other times, only from the left - at slightly different positions (i.e. 1-2 mm up or down).
Here's an example. How do I solve this??
12-14-2018 03:21 PM
Hi jimgale,
Since this issues is happening with bar codes and sometimes other images, I recommend performing a print head alignment. Please click HERE for the steps on aligning the print head.
Once the print head is aligned, please try to print another shipping label. Is there still a gap?
03-10-2019 02:37 PM
I've tried /everything/ - every cleaning option, every method. This has been failing since within the first month I bought it and I cannot determine what is causing it. Please help. All the diagnostics show clean heads, the manual alignment is exact, etc.
03-12-2019 02:32 PM
Hi jimgale,
I recommend speaking with our support group to narrow down the cause of your issues. Please contact our support group at 1-800-OK-CANON (1-800-652-2666), Monday - Friday, 8:00 AM - 8:00 PM EST(excluding holidays).
We look forward to hearing from you.
03-14-2019 08:08 PM
What are the 'real' hours of tech support? Calling near 7:30 PM EST results in at least 40 minutes on hold with music waiting for anyone to answer. I expect they won't today either.
03-15-2019 11:53 AM
Trying again - the voice support prompts are failing. Is there a direct number I can call??
03-15-2019 12:03 PM
Hi, Jimgale! If our voice-recognition system isn't quite understanding you, just hit 0 (zero) on your touchtone phone. That will allow you to bypass the voice prompts and you'll be immediately transferred to one of our call directors, an actual human being who can route you to the correct department for your product.
We look forward to working with you!
01-13-2025 09:19 PM
I know this is another lifetime but my printer just started doing this. Did you ever get it figured out?
11-30-2025 10:43 PM
My printer is also doing this. Can you let us know if you were able to figure out a fix? Thanks!
12-01-2025 12:17 PM
I was forced to go with another brand.
