03-16-2023 12:25 PM
I just installed a new G7020 AIO on a Windows PC and am successfully printing on standard paper from the bottom tray. OK so far. Now I want to print on 5 x 8 inch index cards. I load them into the rear tray, close the little feed slot cover and then have to select both size and type. Index cards are slightly heavier than 20 lb and the 5 x 8 inch size is not among the available selections. Any suggestions how to specify and succeed with printing?
Can I create a custom setting and have the software store it?
Regards...
03-16-2023 01:02 PM
OK to ignore. Twenty minutes of persistent exploration and some trial and error with my new toy gave the results I was looking for. Still climbing the learning curve. TNX
03-16-2023 01:02 PM
