11-01-2023
02:58 PM
03:00 PM
James_C
My G4210 won't print because a "send fax" window pops up. I tried all I can from the web but it is not fixed, can anyone help?
11-03-2023 01:33 PM
Hi jrgust,
I can assist you with resolving this issue, but would need a little more information:
Are you using your PIXMA G4210 wirelessly?
or with a USB cable.
Are you using Windows?
or Mac?
What version of Windows (or OSX) is installed on your computer?
11-03-2023 06:41 PM
I am using a usb connection
Windows 10 64 bit
version 22h2 I'm old and know little about computers, I hope this helps
12-12-2023 09:13 AM
It sounds like the printer fax driver is selected. When you go to print, a print preview window should appear. In this window, select the option to change printer. You should see your printer listed twice, one with the model number and one with the model number with the word fax attached to it.
Select your printer model without the word fax and try to print again.
