02-17-2013 11:22 AM
I have tried resetting , power off, cleaned head.
Still errror message.
Printer in Over 2 years old.
Do I just need a new print head??
thank you!
11-12-2018 02:27 PM
Thank you, while I didn't use the Tom's Hardware method exactly, it's on the right track.
This is a power-surge / outage related issue, and performing a hard reset as detailed above should fix it. Alternatively do what I did and turn off the printer, remove the Windows software driver, then restart and reinstall the driver (with the printer turned back on of course).
Seven pages and Canon can't even pinpoint that this is essentially a software error.
Using a Canon MX922 and Windows 10.
11-17-2018 12:51 PM
Same problem MX922
12-07-2018 03:02 PM
02-04-2019 05:41 PM
Me too. I have a Canon MX700. The error came on suddenly. One day, the printer was working fine. The next day, the "Type of print head in incorrect" popped up. I dismantled everything as the Support Note said. The error persists. Are my printer and spare ink cartridges now simply useless?
02-10-2019 11:14 PM
06-10-2019 12:02 PM
I receive this error on my Canon MG5670.
Have took out and put back the ink but still did not work.
Tried to switch off and on, but still does not work.
Do advise on how to resolve this error on my printer model.
Thank you!
09-10-2019 03:53 PM
I also had this problem on my Pixma MG6220 which appears to be fairly common. Unfortunately, with this error you are not able to use any other function (like scanning) as the error pops up as soon as you turn on the printer. I did what all the forums and Canon support suggests. I cleaned the printhead, reseated it, unplugged and replugged in the machine ... all to no avail as the error still came up.
I searched for a new printhead from Canon. Don't get me started on how hard it is to navigate their website. I couldn't find one there or on Amazon or almost any other site. Figured I would have to buy a new printer as they seem to be throwaways after a while. I really love this printer and it has not given me any problems up to this point. Besides, I had quite an inventory of ink that of course wouldn't fit the new printers. Canon does this on purpose I'm sure.
I finally found a brand new OEM printhead on Ebay for $30. I decided to give it a try because I hear printheads can sometimes run around $130 and I was willing to take a chance on it for that amount. It came in the mail and I popped it into the printer. Voila, it worked! The thing is printing like a boss and I couldn't be happier. So before you throw away the printer, try replacing the printhead.
09-24-2019 10:37 AM
Mine says replace print head. I installed a new $400 print head only to achieve the same error message. Ive tried every tip give throughout this entire thread.
09-24-2019 10:53 AM - edited 09-24-2019 10:54 AM
Wow, where on earth did you find one for $400? Isn't that more than the printer cost originally? I found mine on ebay for $30.
Unfortunately, it may be that the communication between the control panel and the printhead may be compromised. It may be time to look for a new printer.
09-24-2019 11:06 AM
