Double sided printing on G3260
liztull
This is the first printer where I've had an issue setting automated double sided printing. I'm on Mac (Monterey) and the option is grayed out. How can I fix this? (If it's unfixable, that's a huge problem, we're back to the dark ages.)
3 REPLIES 3
liztull
Bumping. Can anyone help with this? I can't be the only person with this issue.
I was checking the manual and was able to see that you can print two sided from Windows but not MacOS. This is most likely due to Windows having drivers and with Mac having to use the built in Airprint.
You can check with Mac to see if they have a way to enable two sided printing from within the built in Airprint settings.
ms33
I am having the same issue. Answer below seems like it is not fixable.
Did you ever find a solution?
