06-06-2017 08:29 PM
Hello -
I just installed a brand new ink cassette into my Canon Selphy CP800 but it won't work. The screen displays the following message...ink cassette is empty insert new ink cassette. Any help would be greatly appreciated!
Thank you!
08-15-2017 02:11 PM
Did you ever resolve this issue? Having the same problem.
08-18-2017 06:02 PM
I have the same Problem with my CP810. Installing a new original cassette helps nothing.
I read somewhere, that inside could be a gear that could be broken. but how to open the printer?
08-28-2017 12:11 PM
Hello - Sorry but I never got it solved. Ended up just purchasing a new one.
11-04-2019 06:20 PM
I can not get the ink cassette to eject. It seems like something is jammed.
11-08-2019 03:09 PM
Hi Icarl94,
Please try the following to see if we can resolve your issue:
1. Turn the printer off.
2. Open the side of the printer to access the ink cartridge.
3. Push the cartridge into the printer to ensure that it is secure.
4. Turn the printer on and back off again.
Once this has been done, try to remove the ink cartridge from the unit.
