09-25-2022 08:43 PM
My 2 year old printer has just started printing fuzzy lines. I get just a few good lines and the rest are faded and partially gone. I have run all the test and cleaners with no change. Can you help?
09-27-2022 11:02 PM
@pslane1,
This is indeed helpful. One of your black cartridges appears to be clogged, near empty or at fault etc.
Run a standard cleaning to see if this helps. If by chance the cartridge is at/near empty, it should be replaced.
This may also be helpful:
Canon : Inkjet Manuals : TS9500 series : If Printing Is Faint or Uneven
09-27-2022 01:55 PM
Did you print a nozzle check after the cleanings? If so, could you attach a picture of your inks and nozzle check to your reply and we can troubleshoot further.
09-27-2022 08:07 PM
Will do.
09-27-2022 08:43 PM
Let me know if these will do.
09-27-2022 11:02 PM
@pslane1,
09-28-2022 08:24 PM
That fixed the problem! So glad it was that fixable. Although the cartridge had a good bit if ink, I replaced it. Thank you much!
10-12-2022 08:27 PM
shadowsports, tried to print a document tonight and I'm having the same old problem. For sure it's a black ink cartridge so I am going to replace the other black cartridge as soon as I can. If you know of any other tricks I can try let me know. Thanks.
