05-22-2022 01:02 PM
New Printer. Scanner won't work. Printer on, WiFi on. Tried with USB connection too. Nothing happens. This seems to have been an ongoing problem with Canon printers for years. Why isn't it sorted.
05-25-2022 03:49 PM
Hi ValCar,
The 5,156,69 error that you are experiencing is caused when security software installed on your computer is blocking the incoming data from your scanner. Please temporarily disable the software or contact that software's support for assistance with allowing the MG3620's scanner through their software. Examples of such software are Webroot, Norton, TotalAV and McAfee.
05-26-2022 06:31 AM
As far as I can see all I've got is Ad Block Ultimate. Does that cause the problem?
05-27-2022 03:46 PM
It's possible and it also could be a Windows built in security/firewall setting. If disabling Ad block does not reslove the issue, please contact Microsoft support. They will troubleshoot the computer itself to narrow down what is causing the communication issue to the scanner.
05-28-2022 07:18 AM
Thank you Patrick. I don't think I have any of those. All I've got is Adblock Ultimate.
