01-25-2016 10:50 AM
I have cleaned nozzles, checked all that I know to check and it just won't print. Wait, I take that back, sometimes it prints when I tell it to, but most of the time it just goes through the motions of printing with nothing actually printed on the paper. I'm using black cartridges only, my ink level shows completely full. Can't figure this one out, would appreciate any help, I'm a homeschooler and I need my printer!!!
01-27-2016 09:12 AM
Hi Cloverbea,
First, please make sure that the ink tanks are installed in the printer correctly and are in the correct order. The order from left to right is as follows:
CLI-251M
CLI-251BK
CLI-251Y
PGI-220PGBK
CLI-251C
Next, a test of the printer should be performed. This will tell us if the printer is working correctly. To do this, please load letter-sized paper in the PIXMA MG5420 and follow these steps:
1. Press <HOME>.
2. Rotate the menu to Maintenance and press <OK>.
3. Press <OK> on Print nozzle check pattern.
4. Press <OK> on Yes.
The Nozzle Check will print. Please compare your printout to the example that has been attached to the bottom of this post. If they differ, please perform a few printhead cleanings.
To perform cleanings, please follow these steps:
1. Press <HOME>.
3. Press <OK> on Cleaning.
5. Press <OK> on Yes.
After a few cleanings, please print another Nozzle Check.
Does the Nozzle Check print correctly? If not, please contact our support group using the following link:
http://www.usa.canon.com/cusa/consumer/standard_display/contact_us_consumer
08-24-2018 09:13 PM
My MG5422 suddenly quit putting ink on paper. It goes thru the motinos but blank sheets come out. Whats wrong? The steps listed here had no effect.
08-24-2018 09:35 PM
Hi RussC,
In order to better assist you, allow me to ask a couple questions:
I look forward to your reply.
08-26-2018 02:25 PM
I get a blank page when I try to photocopy in black or color. I get a blank page when I run a nozzle check.
08-26-2018 02:36 PM
Hi RussC,
It is recommended that you contact one of Canon's Technical Support Representatives. To contact a Technical Support Representative, please use the link below:
http://Canon.us/ContactLI
02-06-2019 06:26 PM
02-06-2019 08:02 PM
02-06-2019 08:02 PM
