Canon G3270 Cannot Print 2.5*3.5
JessieRamirez
I recently purchased this printer after researching it can indeed print on 3.5*2.5 cardstock individual blank cards.
The issue is there is no option to do so, neither on the printer or windows is there a paper size of 3.5 * 2.5. I've tried adding custom sizes which is not possible. I even tried using the Printer Management Form in windows with no success. I have latest drivers.
Any help is appreciated, thank you.
1 REPLY 1
DerrickL
Make sure you do not have borderless checked then set the custom size to what size you want. Borderless printing enabled removes paper custom size in printer settings.
Printing on 2.5x3.5 Cardstock with Canon G3270
Printer Settings
To successfully print on 2.5x3.5 cardstock, follow these steps:
  1. Set Page Size:
    • Access the printer settings on your computer.
    • Set the page size to 2.5x3.5 inches.
  2. Select Media Type:
    • Choose the appropriate media type for cardstock in the printer settings. This ensures optimal print quality.
Loading Cardstock
  • Paper Tray:
    • Load the cardstock into the printer's paper tray. Make sure it is aligned properly to avoid jams or misprints.
Additional Tips
  • Ensure that the cardstock is compatible with your printer to achieve the best results.
  • If you encounter any issues, check the printer manual for troubleshooting specific to cardstock printing.
