06-05-2022 11:15 AM
My printer, along with many others by the looks of this forum, is stuck in a reboot loop. It appears Canon has released a firmware update which must be installed manually while not connected to the internet. But it requires a USB cable. Can the driver be installed using a USB Flash Drive? Can I download the driver to a Flash Drive and install it directly by plugging the drive directly into the printer?
06-05-2022 11:30 AM
If it's not possible, will Canon reimburse USB-B cable purchase since the USB cable wasn't included with the printer
06-05-2022 12:15 PM - edited 06-05-2022 12:26 PM
Yes. Has to be done via USB cable. Since a USB cable is consider an accessory, its not a reimburseable item. Same way a USB stick is considered an accessory.
Hopefully something like this won't present too much hardship:
06-13-2022 07:27 PM
Found this on the support pages:
Method 3: If available, connect the affected printer using the Access Point Mode (also known as Wireless Direct).
So I set up my printer using Access Point Mode Wireless Direct to my Mac. The printer is now showing Idle, default and green so I know it's hooked up.
Now, how do I update the drivers? When I run the utility it says, "Printer Not Found". Any ideas?
06-13-2022 08:31 PM
FW should not be upgraded using wireless. If there is any interruption in the connection, you printer could be bricked. Use a cable.
