Blue lines from ADF only when scanning on PIXMA TR4720
Spotswoc
I have a PIXMA TR4720 that is producing two blue lines across the scanned image when I scan with the ADF. This doesn't happen with the platen glass scanning. I believe what occurred was that I had scanned a blue ink marked up document and the ink hadn't fully dried before I scanned it and that the blue ink somehow got into the inside of the ADF reader.
I performed a cleaning as well as a deep cleaning and that hasn't resolved it. Is there a way to clean the inside of the ADF feeder on this model in some way? Or how else can I clean it to remove the blue lines?
#TR4720
1 REPLY 1
What you describe sounds plausible.  Cleaning operations will not remove ink which may be stuck in the ADF.
You'll have to get creative.  The ADF is not a user serviceable part.  Q-Tips and a very small amount of alcohol might help.
