Canon IP2770 Refuses to print MAGENTA
Rumine
I've modified the printer and so it uses an ink tank.
The installation was successful and it was working until it randomly decided to not print magenta. I've made sure that the ink cartridge actually contains magents, and I've tried to blot it on the tissue to make sure that there is no blockage and it blots CMY perfectly but the moment that I try to print the pattern it would just refuse to use the magenta ink.
1 REPLY 1
Arthur
Moderator
Moderator
Welcome to The Canon Community, and thank you for your inquiry!
We appreciate your participation, however, we need to let you know that the Canon Community is hosted and moderated within the United States by Canon USA. We are only able to provide support for Canon products manufactured for and used within the US market.
If you live outside the United States, please CLICK HERE and select your country or region for your support needs.
You're welcome to discuss Canon products sold outside of the United States, but please be aware that you will not receive support directly from Canon USA.
