12-10-2024
10:03 PM
08:20 AM
Trying to update R5M2. First time went without issue. Now I’m unable to transfer the .fir file to my card. I’m using the correct operating system, Mac. l know to put it in the root. I’ve tried both cards.
what am I missing? Thanks
12-12-2024 08:16 AM
John,
I thought that I would tell you the solution. I’m not real bright. I wrote to Angelbird and asked them. My card and reader are Angelbird. On the reader there is a very tiny switch that prevents writing on the card. That was on. I turned it off, everything worked.
‘Thanks for all your effort.
Hsppy Holidays.
12-12-2024 08:26 AM
Glad it worked out. I never saw that feature on other card readers. It would be easy to miss. Select Solved so others don’t chime in. Happy Holidays to you as well.
12-11-2024 06:32 AM
1. are you connecting the camera by cable or using a card reader?
2. if direct connecting the camera is the computer recognizing it?
12-11-2024 06:56 AM
I’m using the CF card to transfer the .fir from the computer download to the camera, but I can’t get the .fir file on the card. They say just drop the file on the card but in my case the file doesn’t load to the card.
12-11-2024 07:25 AM
Are you using a card reader? Does the computer show you the CF card? Copy-paste doesn’t work?
12-11-2024 07:34 AM
I’m using a reader. When I drag the .fir to the card on the computer screen the file doesn’t load. The card is formatted
12-11-2024 07:41 AM
Strange, but it’s not a Canon problem. It seems to be a computer related problem.
When you have the CF card connected to the computer do you see the camera folders on the root level of the card?
12-11-2024 07:49 AM
Exactly,
I only recall one that is DCIM. I’ve actually tried doing this on two computers.
12-11-2024 08:28 AM
@Scubachuck wrote:
Exactly,
You should see something like this on your Mac
I just downloaded and dragged the .fir file for my camera.
You don't want to drag to the DCIM folder; just drag to the open space.
12-11-2024 08:44 AM
Just so everyone is on the same page - you don't open the .fir file. You move it over to the file onto the card. When you connect the card to your Mac, you should see it mounted (usually on your desktop). You'll also see the firmware update mounted on your desktop (like jrhoffman's screenshot) when you download the firmware update. All you need to do is open the mounted firmware update to see the items, open your mounted card, and then simply drag the .fir file over to the card. That's all. Then, eject the card and put it into your camera.
The mounted firmware also has a folder with PDF files. Those are step-by-step instructions. Feel free to follow along with those!
12-11-2024 10:27 AM
John,
Thankyou for your help.
I just drag it to the card, not to any folder. It just bounces back.
