03-13-2024
12:07 AM
08:57 AM
We shot a bunch of test footage on the R5C using the Dual Fisheye Lens. Per Canon's advertisement, we shot RAW 8K/60fps to give us the best possible footage. My goal was to edit in Premiere to have better control over the color levels than what appeared to be offered in the EOS VR Utility app.
I've now downloaded the EOS VR plugin for Premiere Pro, but when I import my RAW footage, I can't seem to find the controls to change them into equirectangular format.
I searched for instructions and was pointed towards a solution of clicking on a clip in the timeline and selecting the Source tab, but there isn't anything there. I found several threads mentioning that an earlier version of the plugin wouldn't work with RAW files, only mp4. Is this still the case?
Does that mean Canon is advertising that their lens, on one specific camera, is capable of shooting 8K/60fps, but if users shoot at that, they're only able to use the lesser of two editing options? Am I missing something?
03-15-2024 05:09 PM
Hi VeerPearl,
I double checked and it is still the case that the EOS VR Plugin for Adobe Premiere Pro only works with .MP4 files. That is not a way to use that plug in with other file types. We would recommend using our EOS VR Utility to convert the file into an MP4 format.
03-15-2024 05:09 PM
Hi VeerPearl,
03-19-2024 01:44 PM
Thanks for looking into that. I wish Canon had been more up-front about that, but I suppose I'm glad I didn't grab the subscription for the plugin immediately. To heavily advertise that the system is capable of 8k/60fps, and then have one of the two required pipeline steps not be able to facilitate that is…not good.
10-17-2025 08:31 PM
Despite converting from .CRM to .MP4 files with VR Utility - the MP4 files are still not triggering the Plugin. What else can we do. It would be great to also see a Youtube describing the best possible way to export VR files for the Apple Vision Pro - which did not exist when Canon did their Youtubes for VR back in 2021 and 2022.
10-17-2025 08:32 PM
agreed and it is still the case in October 2025 after they released ver 1.7 of the Plugin.
