Questions on CR2 codec and DPP 4 updating folders
dapelfrey
1) I have been unable to figure out how to see thumbnails of my RAW CR2 files from my previous T3i and new T7i in Adobe Photoshop Elements.  Is there a codec I could download which would solve this problem?
2) as a workaround for the above, I have been using DPP 4 to view the raw files before processing them in Elements.  However, recently when I've added files to folders, DPP 4 has not updated the folder to show the new files.  I tried reinstalling the latest version of DPP 4, but it didn't help.  Any other suggestions
7 REPLIES 7
kvbarkley
Where are you trying to see the previews? If the trouble is opeining the files, have you tried File->open in camera raw?
I've clicked on Open in Camera RAW and still don't get thumbnails for my CR2 files.
jrhoffman75
What operating system? If you open the file folder the images are in do you see them in the folder?  Is your Elements up to date? If DPP isn't seeing the files when you select the folder they are in it sounds like you might have a file problem.
What OS are you using?  Where are the files being stored?  If you do not see thumbnails, then what are you seeing?
In Windows 10, you may have to tell the OS that folder is being used to hold media files.
I'm using Windows 10 Home.  The files are stored on an external SSD.  I see older CR2 thumbnails in the current folders when I open DPP 4.  But if I move a file from one folder to another in File Explorer--or if I change the name of the folder-- DPP 4 doesn't update.  And I can't see the CR2 thumbnails in File Explorer or Photoshop Elements 2019.
Good suggestion about the media file folders--I hadn't done that--but it didn't work.
jrhoffman75
See if this helps
https://www.microsoft.com/en-us/p/raw-image-extension/9nctdw2w1bh8?activetab=pivot:overviewtab
dapelfrey
I tried that before but reinstalled it just in case—still didn’t help.
Friends and Family
