Problems with the New firmware 2.0 in canon R5
serazan
I just updated my canon R5 firmware 2.0 and the wheel I have on top to set up the diaphragm opening (f) doesn´t work properly and skip some positions and it doesn´t move the parameter at all. If I move for example 4 positions in the wheel maybe changes 2 times only insted 4 as it should do it. It has happened to you?
Greetings ,
Please start by resetting your camera's main and custom settings to defaults.
Now put the camera into shooting mode Av and retest.  The aperture will not change a full stop with each click of the main dial.
3 REPLIES 3
Greetings ,
Now it's working fine, Thanks a lot 🙂
Thanks for the reply and your feedback.
