04-18-2024 02:30 PM
Hi~ Since there is only a Windows exe file to update the firmware, how does one update the firmware on their R6 Mark II? I downloaded the file per instructed by the support team, but my computer can't run it so now what???
#r6markii
04-18-2024 03:19 PM
The file is also available for macOS, you just have to tell the site you're using macOS Ventura (even if you're not):
04-18-2024 03:14 PM
Just update via your phone and the app Camera connect. Easy.
04-18-2024 03:19 PM
04-18-2024 06:46 PM
I found it using Ventura and downloaded and it just won't extract... Very annoying. I haven't actually set up the Connect software yet... that might be the only option.
04-18-2024 06:49 PM
I actually did find it and now it's working. Thanks!
04-18-2024 06:49 PM
What happens when you run the .dmg?
If you don't see the extracted folder, open Finder properties, put a check in the Hard Disks option. Now run the .dmg again and look for the folder on your desktop.
04-18-2024 06:51 PM
Good. Sounds like you got it. 😃
05-26-2024 11:31 AM
I'm running into this same issue, as my MAC is Sonoma 14.2.1 only offers utility, no firmware for my 6D Mark II. Are you sure I can go to the previous Mac option to run the firmware offered?
05-26-2024 11:41 AM - edited 05-26-2024 11:42 AM
This thread is about the R6, but yes, 100%. I opened it on Sonoma 14.5. It's just a disc image. It puts the mounted image on your desktop, by the way.
05-26-2024 11:57 AM
When I double click the white file I get this pop up. Am I not to open it, but just drag it to my blank SD card?Screenshot 2024-05-26 at 11.55.57 AM.png
