09-29-2023
01:11 PM
01:12 PM
SamanthaW
I took still images with the dual fisheye lens attached on my Canon EOS R5 C in RAW format. I start the EOS VR Utility and click "Still" in the upper left area and then do File => Select Folder. I've tried selecting the folder with the raw images and I get a dialog box "There are no clips.". I exported them via Lightroom as jpeg to a folder and tried again. Still "no clips". I also tried changing the extension from jpg to JPG and still no clips. I tried version 1.2 originally and then updated to version 1.3 and still no clips.
The manual says "JPEG images produced from RAW processing without in-camera resizing or cropping"
I'm on an Apple M1 Max MacBook Pro running Ventura.
Oh... I wonder if I need to convert them with Canons EOS Utility?
09-29-2023 01:39 PM
@pedz wrote:I took still images with the dual fisheye lens attached on my Canon EOS R5 C in RAW format. I start the EOS VR Utility and click "Still" in the upper left area and then do File => Select Folder. I've tried selecting the folder with the raw images and I get a dialog box "There are no clips.". I exported them via Lightroom as jpeg to a folder and tried again. Still "no clips". I also tried changing the extension from jpg to JPG and still no clips. I tried version 1.2 originally and then updated to version 1.3 and still no clips.
Yes... that seems to be the trick. Using Canon's DPP and exported as JPEG, now the VR utility is happy.
09-29-2023 01:39 PM
