12-20-2020 02:00 PM
I'm using the DPP tool to do focus stacking. Works well, but the produced jpg has no EXIF information. How can I get the EXIf information from the soure transfered to the output image? Couldn't find anything obvious in the preferences.
12-20-2020 04:01 PM
I don't think that there is supposed to be any. You're creating a composite image from several images, each with their own EXIF data. What do you think the EXIF data should contain?
12-20-2020 08:16 PM
12-20-2020 08:45 PM
@milind wrote:
This is depth compositing. There isn't a whole lot of difference between the Exif information between the first and last picture. It could pick up the first or the last image to get the Exif information from.
You're making a false assumption. Different SS and ISO values would give identical exposures. If you wish to copy and paste the info your images, then I suggest that you do that. It is not going to happen automatically, simply because it shouldn't, IMHO.
12-20-2020 08:59 PM
12-20-2020 10:14 PM
@milind wrote:
I'd imagine the vast majority of the focus composting cases is for macro photography.
But yeah, looks like I'm going to have to do it manually using exifTool. Annoying.
Thanks! You just cited THE reason why it should NOT be done automatically. The "vast majority" is not 100% certainty. As long as exceptions can exist, then it will probably never become automatic. So, yes, you will have to do it manually.
12-20-2020 10:59 PM
12-21-2020 02:09 PM - edited 12-21-2020 02:14 PM
@milind wrote:
There is absolutely zero reason why this can't be decided by the user. So yeah, it should at the very least be an option. It's easier to delete all Exif data then to copy all the fields manually. So yeah, definitely the wrong decision.
I agree. The user has the option to add it manually.
12-21-2020 02:15 PM
I do not know of ANY photo software that does it. Do you?
04-18-2024 11:56 AM
Any photo software that preserves the exif data of the RAW file during focus bracketing? Well, the two I have tried so far: Photoshop and Helicon Focus, they keep the exif during focus bracketing
