EOS R5 firmware V2.0 availability for macOS Big Sur
bqfraboni
I have a MacBook Pro running Big Sur 11.7.1 - I received an email that my R5 had a firmware update for 2.0 but it doesn't show on the Canon website dropdown for this OS.  My cousin has MacOS Sonoma V14 and it shows up for her.  Does this mean I can't use this Version 2.0 on my R5?  Also, my computer doesn't see my camera and I'm on R5 firmware V19 and the Big Sur 11.7.1.  Any suggestions? Thanks, Barbara
Camera firmware is OS agnostic so you can pick any version where the firmware is available. I see it listed under OSX v12, 13 or 14.  The .FIR file is the same for the camera regardless of which OS you select.  🙂
3 REPLIES 3
Thank you - we'll give that a try.  Barbara
Thanks Barbara.  All of the downloads include a .PDF with instructions.  Biggest takeaways.
User a freshly formatted SD Card, put the .FIR file in the root directory of the card.
If you have a CFExpressB card installed, remove it temporarily during the FW upgrade.
Use a fully charged battery
Once you select Firmware in the camera menu's you'll see the prompt to upgrade from version to version >
Use the Quick Control dial (rear) to move focus to OK, then press the Set button.
Do not operate the camera or press any buttons until the FW update is complete.
