‎11-17-2024 09:37 AM
Hello, I'm using Premiere Pro 25.0.0 and EOS VR Plugin 1-5-10-2-10I on Macbook Pro M1 (Sequoia 15.1)
I've paid the annual subscription of the plugin.
But the plugin does not appear in Premiere.
How to proceed?
Much appreciated, Pablo
‎11-19-2024 05:56 PM
Hello chantus,
‎11-20-2024 10:46 AM
Thanks for the response. It’s exactly what I’ve done. But there is no Eos plugin in the effects panel of Premiere Pro. And if i import a raw footage it doesn’t show any built in plugin either.
‎11-20-2024 06:14 PM
Greetings chantus,
Thank you for providing us with the additional information and confirming that you have followed the instructions to install the plugin. Were there any error messages when installing the plugin or was the installer able to provide any confirmation that the installation was successful?
In case the installation was successful, please check to see if other plugins appear within Adobe Premiere Pro. In case there are any additional settings that need to be implemented within Premiere Pro for plugins to function, then we suggest on reaching out to Adobe for additional assistance.
‎11-25-2024 12:09 AM
There weren’t any errors during installation process (did it twice) and it finished successfully. I entered the Adobe forum and it seems that many others are having the same issue, and of course they suggest to contact Canon, the plugin creator. They discuss if the plugin is actually ready for apple silicon chips, to try open premiere in rosetta mode (no luck either), but there is no solution. Also they say that raw files are not supported, but converting them to mp4 doesn’t show the plugin either. And yes, all my other plugins are showing and working well: Boris Fx, FxFactory, Izotope, Filmconvert, Cinematch, Red giant, just to name a few.
‎11-25-2024 01:30 PM
I'm having the exact same problem. Please post if you are able to find a solution.
Thanks,
Martin
‎11-25-2024 06:13 PM
Hello chantus,
Let's try walking through the subscribing steps to ensure that we have access to the plug-in. I have attached a link HERE to walk you through that process.
‎01-05-2025 11:20 AM
Hello John_Q,
I've tried that wprkflow step by step several times, with no luck. Other people have the same issue in facebook groups. I've recorded my screen so you can see the issue. Any help appreciated.
https://www.dropbox.com/s/7wbv67t9ndem1am/VR%20issues.mov?dl=0
‎01-08-2025 11:48 AM
Hey, i too have this problem and the support is the worst. Did you perhaps find a solution? 🙌
‎01-08-2025 05:05 PM
No solution yet. Actually Utility VR plugin doesn’t work either. I’ll need to find a windows machine to try if the issue is only mac related
